For those that haven't seen my previous posts. The unit I'm working on is a model 50372R. <br /><br />I've finally been able to remove both the shift mechanism and the prop shaft. I'm still hung up on the drive shaft removal. My question is, how is the forward gear held in contact with the pinion gear?. With the prop shaft out shouldn't the forward gear be disengaged? The parts breakdown shows an oil pump assembly at the end of the forward gear. Is there a spring or something that should push down to release the forward gear from the pinion. I appreciate everyones help.
