73 johnson 115
67-69johnman
I recently purchased a 73 Johnson 115 outboard and my question is does this have some kind of crude charging systwm?
I trickle charge the starter battery before and after every use. But do I need to do this?
I have a 60 Johnson that has a dc generator on it that charges my battery but this one is a little smarter than I.
The model number is 115esl73m
Joe Reeves
Re: 73 johnson 115
The 1973 115hp Johnson has a built in alternator to keep the battery charged. However, should the rectifier be faulty, this will eliminate the charging circuit. Test the rectifier as follows.
(Small Rectifier Description & Location)
(J. Reeves)
On most 2,3,4,6 cylinder engines, the small rectifier is located on the starboard (right) side of the engine just in front of the engines electrical wiring strip. There are a few older V4 engines that have the wiring strip on the rear portion of the engine and the rectifier would be located just under that terminal strip. The smaller horsepower engines usually have the rectifier located on the starboard side of the powerhead close to the carburetor area.
The rectifier appears to be a round object approximately one inch (1") in diameter and also about one inch (1") high. The base of it is sort of triangular in appearance and is attached to the engine with two (2) screws/bolts..... usually one screw/bolt is larger than the other. The rectifier, depending on which one your engine uses, will have either:
One Red wire, one Yellow wire, and one Yellow/Gray wire, or One Red wire, and two Yellow wires.
Note that either of the above rectifiers could have a fourth wire which would be Yellow/Blue
(Small Rectifier Test)
(J. Reeves)
Remove the rectifier wires from the terminal block. Using a ohm meter, connect the black lead of the ohm meter to the rectifier base (ground), then one by one, connect the red lead of the ohm meter to the yellow, yellow/gray, then the red wire (some rectifiers may also have a fourth yellow/blue wire. If so connect to that also). Now, reverse the ohm meter leads and check those same wires again. You should get a reading in one direction, and none at all in the other direction.
Now, connect the black lead of the ohm meter to the red wire. One by one, connect the red lead of the ohm meter to the yellow, yellow/gray, and if present, the yellow/blue wire. Then reverse the leads, checking the wires again. Once more, you should get a reading in one direction and none in the other.
Note that the reading obtained from the red rectifier wire will be lower then what is obtained from the other wires.
Any deviation from the "Reading", "No Reading" as above indicates a faulty rectifier. Note that a rectifier will not tolerate reverse polarity. Simply touching the battery with the cables in the reverse order or hooking up a battery charger backwards will blow the diodes in the rectifier assy immediately.
67-69johnman
Re: 73 johnson 115
I will tackle that when I get home for sure.
In your opinion is there a so-called Achilles heel to these big old 115s?
Joe Reeves
Re: 73 johnson 115
No, 1973 was the starting point of perfection.... ideal ignition system still in use today, a step in the right direction pertaining to the shifting system. I have nothing bad to say about the 1973 models.
