hi, im restoring in a word a 73 johnson im already replaced the plugs, cleaned the carb, pistons are moving freely, selects gears but ....
only getting a spark in one plug so today took the top off to check the points to find the ignition coil that had no spark with cracks all in the casing.... i have two questions
1) how do you check if they work?
2) i have found what i believe to be a replacement on ebay brand new is it as simple as that do they just swap or are the specific?
http://cgi.ebay.co.uk/JOHNSON-EVINR...VQQcmdZViewItemQQ_trksidZp1638Q2em118Q2el1247
thanks Gav
thanks Gav
