As above at higher revs the pee hole stops ejecting water and the engine fluctuates. Have stripped water pump and all is ok with plenty of life left in it (although there was a lot of salt in there), also flushed hose pipe up the water feed pipe and water freely runs out of the pee hole and the exhaust tube.
Is it likely the heads are blocked with salt? Is there a way of flushing them without removing them?
Many thanks
James
Many thanks
James
