ezmobee
- Joined
- Mar 26, 2007
- 23,767
I got my boat all ready to go this year and started it in my driveway. I really wanted to make sure the motor was pumping water properly so I didn't use the muffs. Sometimes it seems like the garden hose pressure forces the water where it needs to go so you can't quite tell if the water pump is working correctly. Instead I filled this giant truck box I have up with water and lowered the motor into that. Well near as I could tell, it wasn't pumping water AT ALL. Unfortunately it took me a while to definitively determine this with the exhaust stirring up the water so bad. Just about the time I was coming to the conclusion that it wasn't at all pumping and that the block was getting very hot, the overheat horn sounded. I immediately shut it down. My first question is do you think I did any damage to the motor with this quick overheat? It probably ran for 5 minutes or so total.
Anyway, I assumed my impeller was toast so today I dropped my lower unit. My impeller looks to be in OK shape. Not perfect but good enough that it should have been pumping. But what I did see that was weird is I am missing one of the plastic tubes that connect the impeller housing to the tubes that run up the midsection. I'm assuming that is my problem. (I'll be replacing the impeller anyway of course since I have it apart.) What could have happened to the tube? Or how could it have worked without it? I've been using it for 2 full seasons since I last had it at the shop to have it "awakened" when I bought it which included an impeller change.
