My FIL gave me this boat & I am trying to fix it up. It?s pretty cool. It steers from the front seat with a slot machine-type handle. Somebody told me they call it a crappie boat.
1) Performance issue you are trying to correct.-
Prop is chipped & slightly bent.
2) Current prop manufacturer, model, aluminum or stainless-
Aluminum. The only markings are-Michigan PR 337
3) Current prop diameter and pitch (required).
I have looked everywhere online as to what prop this is & came up skunked.
4) Wide open throttle RPM and speed with an average load (very helpful).- No tach. It gets up on plane well with 400+lbs of people & equipt.
5) Engine/drive make, model, year, and HP-
1973 Mercury 500 50hp
6) Boat make model, year, length and weight-
1973, Skeeter K-4 Metro 15.33 foot outboard. The weight of the boat is 675 lbs. 400lbs added for people.
I took the prop off to find some info on it & it was only attached with a nut and then a larger knurled thing (sorry, best I can describe it) with splines. There is no tab washer or brass washer like I have seen in some of your prop removal diagrams. Also, where the shaft comes out of the lower unit there are four evenly-spaced ports(?) (sorry again) These are packed with hard rubber but not smoothly. It doesn?t look like the rubber belongs in there. Are these exhaust ports & should I dig the rubber out?
Man, I feel pretty stupid right now. I don?t know what pitch or diameter this Michigan prop is & I can?t tell you guys what rpm or speed. Thank you in advance for any help you can give with the terrible info I?ve provided.
