I finally got my boat in the water and all is well except that when shifting from forward to neutral i have to go past neutral to get it out of gear same as going from reverse to neutral i have to go past neutral to get it into neutral i have adjusted the lower shift cable when i put it all together did i adjust it wrong or is there another adjustment to make also the boat is an 18' starcraft aluminum top speed is around 37 mph at 4000 rpm with a 21 pitch prop on choppy water is that ok or should i look for a smaller pitch ? boat is mainly for fishing
ps: thanks to all the great people here i couldn't have got this far without you i read this forum almost every night all winter long learning all that i needed to know to get my boat this far
