Ok. I have searched, read, and re-read, but I am more confused now than ever. I have a '73 15 ft MerriMack fiberglass tri-hull. I knew there was a soft spot in the floor when I got her. Finally got around to cutting it out, which turned into me taking out the deck in the entire passenger area to finally get to good wood. Of course, you all know what I found, a lot of foam and "some" water. I have pulled all of the foam and checked the stringers. Believe it or not (I couldn't), they are good! Given this piece of luck, I have a few questions on which I would appreciate any guidance:
1. What do you recommend I use to fill the nail holes and minor (< 1/8") cuts I made in the stringers. They're not rotted, and I want to make sure they stay that way.
2. The stringers have no limber holes in them. Should I drill some? If so, how big and how do you seal them?
3. Since its a fiberglass boat, do I need to use the pour foam for structural rigidity? If I do, how does the water drain back to the bilge? I know a lot of you don't like the foam and given what I found, it seems to me it would be better to use some material that would allow the under deck area to breathe. As I said, I'm more confused now than ever.
Sorry for all the questions, but this is my first attempt at boat work. I've never glassed before, but have read as much as I can on here and even practiced on a couple of pieces. I know just enough to be dangerous. By the way, I have already coated the replacement pieces with resin to seal it. I'm using exterior grade 3/4" plywood. I poured the resin along the edges to really seal them up. Thanks to everyone who has made this place a great compilation of knowledge.
