patagoniapete
- Joined
- Aug 21, 2014
- 17
I have a 1974 Evinrude 135 Strangler. The tach on this boat doesn't work and so I tested the rectifier which tested bad. I ordered the rectifier but, after reading some posts here, it made me think that I should test the charge coils on the stator as well. The book calls for some kind of "neon test" and I have no idea what that is. Do they go by another name? Is it an outdated test or is there just another way that we test them now?
I read on one of the forums to test the resistance of the charge coils using #7 & 8 leads off of the power pack. They said the ohm's should read between 550 and 700. I got a reading of 749. Is that too far out of range?
Are there symptoms that the boat should exhibit if the charge coils are bad? The problem that I have been having with the boat recently is that it takes a good 30 seconds for it to accelerate at WOT, but once it gets up there it does great. I rebuilt the carbs and have ordered a fuel pump but haven't had time to check the results on the water yet. I'm just worried about the charge coils because they're $300 and I really want to make sure its necessary before I throw that kind of money at this thing.
