Re: 74 40horse top plug fouls
Whoa, hold up there. That's getting kind of extreme when you haven't even diagnosed the problem.
You say "no spark--regaining spark". Are you talking about spark across the plug gap or spark off the coil wire? If you have no spark off the coil wire, you have a definate ignition problem. But if it is the plug that is shorted out, it could be water or a half dozen other things.
If you determine that it is shorting plugs, It may be the fuel pump. Without looking, I don't know which cylinder the pump is mounted on. If it is the top one, unbolt it from the cylinder and give the squeezer bulb a mash. If gas squirts out the pulse hole in the pump you have found your problem.
If it is a water intrusion problem, there should be water droplets on the plug. I'm going to tell you something here that I do not reccommend because there is extreme danger of fire. But I remove the plug and securely ground the wire away from the plug hole. Then start the motor and hold a piece of glass or mirror in front of the plug hole. If there is water intrusion you will see droplets of water on the mirror, along with oily fuel. WARNING! I told you there is danger of fire, so "don't do as I do"----etc
