Re: 74 70hp johnson Tach wire location?
Hi ya' Tin Can....<br /><br />On OMC (now Bombardier) engines, the tach wire is the gray wire in the wire harness. Connect the gray wire to the "Signal" post on the tach. It should be in the harness that goes up towards the dash. Most likely it will be "Taped" off.
