74 evinrude 15 hp starts and dies
boulevard
I just bought a 74 evinrude 15 hp yesterday and need help getting it running. The previous owner said it ran which I guess technically wasn't lying because it does turn over but dies immediately following. If this is not an easy fix I need to get my money back. I probably pulled it 100 times today and it ran for about 3 seconds each time. Help appreciated
AlTn
Re: 74 evinrude 15 hp starts and dies
read the Top Secret Files at the beginning of this forum..anything having to do with compression, spark, and fuel...gotta have those...as a start I'd suggest you spray some fuel/oil mix in the carb throat, close the choke and see if it'll fire as you pull it....compression check is the most critical as it will be the most costly to fix < if more than a blown head gasket>, check the lower unit lube..if more water comes out than grease...you may really want to consider that money back offer
raczekp1
http://www.sschapterpsa.com/ramblings/Ramblings.html
and
OB Basics on Starting an Motor That is Resisting
8 OB Neptune Mighty Might 1.7 hp 1956 Outboard Restoration Project
9 OB Elgin 2.5 hp 1947 Outboard Restoration Project
10 OB Mercury 4.5 hp 1975 - 1985, Getting it Running Again
11 OB Johnson / Evinrude Year/Model Code Identification
12 OB Johnson 10 hp QD Series Motors 1949 - 1963
13 OB Johnson / Evinrude 6 hp 1969 - 1979
14 OB Johnson / Evinrude 8 hp 1992 version
15 OB Johnson / Evinrude 9.5 hp Normal Repairs 1964 - 1973
16 OB Johnson / Evinrude 9.9 /15 hp 1974 - 1976 Magneto Ignition
17 OB Johnson/Evinrude 9.9 / 15 hp General Info & Normal Repairs 1974 - 1992
18 OB Johnson/Evinrude 9.9 / 15 hp Powerhead / Midsection Repairs
19 OB Johnson/Evinrude 9.9 / 15 hp Carburetor / Fuel Pump Repairs
20 OB Johnson/Evinrude 9.9 / 15 hp Lower Unit / Water Pump 1974 - 2005
21 OB Johnson/Evinrude 9.9 / 15 hp Water Circulation Problems
22 OB Johnson/Evinrude 9.9 / 15 hp Troubleshooting
23 OB Johnson/Evinrude 9.9 / 15 hp Converting Shaft Lengths 1974 - 2005
24 OB Johnson/Evinrude 9.9 / 15 hp Converting to Electric Start 1974 - 1992
25 OB Johnson/Evinrude 9.9 / 15 hp Normal Repairs 1993 - 2005
26 OB Johnson/Evinrude 9.9 / 15 hp Converting to Electric Start 1993 - 2005
27 OB e-Bay Motor Rebuild & Why it Blew a Piston After a Rebuild
28 OB Rebuilding the OMC pre 1987 Fuel Pump
29 OB Rebuilding the OMC post 1990 Fuel Pump
30 OB Converting the Old Dual Fuel Line pre 1959 to the New Single Line
31 OB Converting a 70 hp Console Control Motor to Tiller Control
32 OB Outboard Motor Trim / Tilt Motor Replacement
33 OB Most Boats & Motors are Ruined by Negligence
34 OB Submerged Motor Recovery
35 OB Outboard Jet Maintenance
36 OB Winterizing an Boat & Motor
