Re: 74 Merc 85hp Water Pump Problem
Where is the water barely coming out, the telltale? That may be just a simple clogging problem. Blow it out with compressed air, run a wire up the telltalle/hose, or pull the hose off and clean it out.
If you're getting water spitting out the exhaust reliefs when you're on a flusher, that's a good amount of water flowing thru the motor. I bet there's a real good stream of warmer water coming out of the prop hub.
Feel the exhaust manifold (Port side, big flat cover) and it should be quite cool. If it's getting extremely warm while you're idling on the flusher, you're not "watering" the powerhead properly. If it's cool, you're probably OK.
If you do find you're having a circulation problem, pull the lower unit and make sure the guide tube on the water pump is in place and it catches the copper water tube as you're installing the lower unit.
Check to make sure the rubber water tube grommet is in the pump housing. Flow water up the copper tube and see where it all goes.
Cheers..........ed
