Tofuminator
- Joined
- Feb 5, 2012
- 18
Changed the gear lube for years with no problem, now I put in fresh gear lube and run the motor for 5 minutes, lube comes out looking like MILK. Assuming lower unit leaks, I called some outboard shops they said the steel shafts on these are messed up and it's not worth replacing seals. Just use 105 gear lube and keep topping off.
Is this true???????????
