74 Starcraft American 15 stringer and transom
Jeff_40
wAAACH5BAEKAAAALAAAAAABAAEAAAICRAEAOw==
​ I’ve just finished ripping my floor open everything is over 50% rotten so I’ll be replacing it all. For the transom the wood was 3/4” think I’ve read elsewhere someone had the same boat with 1 1/2” thick transom would it hurt to double it up? I’m not sure what to do with the stringers do I run new fibreglass matting over the wood again or can I get away with just cloth? Also
​ can I make them larger I’ve attached some pictures not sure if I should piece I back together as is or beef it up a little any suggestions would be great (all those bud light cans were from the previous owner wouldn’t touch that stuff with a 10 ft pole)
Transoms are 1-1/2" thick
Stringers need CSM and 1708 if your using pily
Read the DIY sticky links 14, 18, 2, 3, and 4
Jeff_40
Thanks Scott appreciate the help the wood is only 1” wide and the stringers are 1\2” would it hurt to double up or best to keep it the same?
