I have a 1975 4hp that seems to have a small split in the water pump housing. The parts store only lists replacement impellers and plates. It doesn't appear to go all the way thru the housing, but it juts out a bit on the inside where the impeller rides, and it is clearly noticeable by feel.
It wasn't cooling, and while the impeller that came out is clearly worn some, it looks like it should have pumped water. The motor is new to me, and I have not had the head off yet to check if all water passages are free of debris.
Any suggestions on whether the pump housing could be the culprit ( My guess is that while it maybe should be replaced, as well as the impeller, there is some other reason why it isn't circulating water and cooling) or something further needs to be checked?
