'75 40 hp Johnson will not run at full throttle
twostep
Motor starts, runs at idle speed pretty good, a little rough. When increased to full throttle the engine will go to full throttle for 5 - 15 minutes then drop back to 50%. From there on it will cycle.<br />Have replaced the fuel pump, carb. kit, points & condenser, plugs and one coil that was loose.<br />Points and plugs were set to manual specs. The motor did the above describe before all the changes.<br />What am I missing? Do I need to check the carb. again? Could it be vacuum problems? Pleas help!
fireman 757
Re: '75 40 hp Johnson will not run at full throttle
sounds like an ignition coil goin bad. Pull a plug wire and run it does it do the same thing? Then pull the other. Now what does it do? When you pull one it probably won't start because you are running on one cylinder. Change the bad coil and your in business.
