Having replaced the steering cable, I was moving onto the shifter cables. I have a Quicksilver 3000 series, side mount, checking with the engine off it seems okay when I put in it forward gear and increase the throttle. What I did note was that I could not put it in reverse. Does the engine have to be running to put this in reverse gear? I seem to recall I reading something that you cant shift into reverse without the engine running...and that maybe turning the prop while trying to shift into reverse would help.
