75 hp evinrude fixed by your advise
michealbugs
I posted several questions conserning my 75 hp idleing.(ran good at speed but wouldn't idle after warming up) I tried everything and couldn't find anything wrong. As per advise from several of you I went to the FAQ and decarboned by way of seafoam and gas oil mix. I did it three times and tho it was still smoking the engine began running like a new one. I am wondering if I should do it a few more times (untill it stops smoking)Or is the mix of seafoam causing the smoke also? All I know is that I sure feel alot better about my motor and want to thank all of you on the good information. THANKS
iwombat
Re: 75 hp evinrude fixed by your advise
Outboards smoke a little always. Just keep mixing seafoam in to the fuel as per directions on the can, or if you want, double it for awhile. You won't hurt anything.
