75 HP Evinrude Leaking Trim & Tilt seals
flfreediver
I have a 1983 75HP Evinrude with leaking trim and tilt cylinders. The trim cylinder seals look easy to change, but the tilt cylinder has a tee on the end. I've already removed the locking pin which attaches it to the motor, but am having a hard time removing the tee which is attached to the shaft on the tilt cylinder, in order to remove the seal. Does anyone know how to change the seal on the tilt cylinder?<br /> :confused:
