75 HP Weight Range Class? Such as a 75 HP VS 90 HP.
JesterGrin_1
I have a set of boat plans that has a minimum of a 75 HP Motor. And was wondering what HP motors are there in the same weight class or close to it? And of Course an Older Johnson/Evinrude. :)
emdsapmgr
The 75 engine of yore is a 3 cylinder engine. These were small cube engines of only 49 cubic inches. A "high port" engine, it was a dog out of the hole (not a lot of torque) but loads of high rpm capability. Would work good on a really light boat. The 20" shaft engine weighed 248 and the 15" short shaft engine weighed 198. Some time in the late 80's the displacement was changed to 56 cubic inches and only sold as a 70. It's got some low end grunt. The big brother 4 cyl crossflow was nearly 100 cubic inches and came from 85 to 140 hp. right at 300 lbs. As far as I'm concerned the V4 will run circles around the 70/75. Today's hp comparable 4 stroke engines are heavy compared to the old 2 strokes.
JesterGrin_1
Great maybe I can get some input. Since I am looking for a Motor in the 75 HP weight class which might be the best to look for?
I wished to add that a 2 stroke would be great and with a 20" shaft or some call long.
The Boat will be made out of wood in the Panga type Design with a Length of 18' and a Beam of 6'6".
Thank You.
