'75 Johnson 15hp Seahorse intermittent miss @ low RPM's
Normaly when coming off plane, from 1/2 throttle to idle the engine seems to cut out, or miss. <br /><br />One of the blue power packs is cracked a little, and the other one (power pack) was replaced because of a stubborn idle (like what I am talking about) before I purchased the motor. (the one that is cracked now had checked out OK at the dealer before I had the motor) <br /><br />I know the comp is good, points are set, and I assume the driver coil is opperating correctly as well.<br /><br />There is no hesitation once the rpm's are high and the boat performs reasonably well. (12ft alum)<br /><br />Any thoughts? Perhaps I should just replace the other blue coil...<br /><br />THANKS
