'75 Johnson Seahorse update
crazyls2
Good morning all. I couldn't find my original trend but I wanted to update you guys on my progress. With the help of your input I was able to get my wiring redone for my ignition, that took some work but eventually I was able to get through it. The manual that I was encouraged to buy actually was a big help. The remote issue, turns out if you take the selector (thing that you push forward or pull backwards on the remote to drive forwards and backwards) off you are able to get the plate behind it off so you can put the spring and ball back in. It wouldn't go into reverse because the linkage was in need of adjustment, once it was adjusted it worked great both ways. Rebuilt the carbs and they were in need of adjustment afterwards.
I have a few issues that haven't yet been resolved but I was able to take the boat out this weekend. Those '75 Terry Bass boats sure to ride well on the water. The 50HP motor won't win a speed race but it gets on plane quickly and it will move across the water very well.
Again, thanks for all of your help!
