75 mercury 850 weird issue and noise
justtwistit
Ok so I have a 1975 merc 850 85hp outboard that has problem that I can not figure out.
Motor has 150psi in each cylinder and nice blue spark to each plug (checked using a Briggs and Stratton spark tester).
The boat runs great when I first back off trailer and drive around. When I stop at island to swim and play around for about an hour or so the boat when start fine and idle. The issue is that when I go to click into gear the boat will bog down and die. Sometimes when its about to die it will nake a horrible squealing noise like belt or bearing. When that happens the engine bogs down and dies. I can restart with no issue and it will idle at about 650 rpms. I have to play with throttle lever and main lever to get the boat going again. Once I'm in gear and driving I have no issues. I can come back down to idling while still in gear and the boat will just run right along.
I have rebuilt carbs, changed plugs, rebuilt fuel pump, changed fuel line on motor.
As far as the noise I believe it is coming from the distributor. I think the bearings might be binding up when hot but it only does it at idle never under way.
If there is any more info I have give let me know and thanks for the help.
Chris1956
Agreed, since that motor has a distributor, the bearings may be going bad. They are replaceable, but the distributor needs to come apart, and it is not obvious how. I would recommend a factory service manual.
As for the stalling in-gear, that is very common. It is usually dirty carbs, incorrect idle mixture adjustment or idle speed too low.
justtwistit
Ok I soaked carbs in carb cleaner bucket for a few hours and then rebuilt with new gaskets float and needle and seat. I have both needles set at 1 1/2 turns out. The tach reads between 600 and 700 rpms
when idling in gear. I will try to readjust the needles to see if that makes a difference.
As for the distributor I will see if I can find some one to help me as I looked on line and they used a special wrench to hold rotor shaft to remove nut on other side of housing
Chris1956
I took a distributor apart, just like the one you have. It required no special tools, Unfortunately, I do not remember much more about it than that.
Good luck.
justtwistit
Ok so update to my issue incase someone else is having similar issues. The bearings in distributor was bad, really bad. It actually ground into housing.
Bought a new cdi distributor housing to be safe since that was original trigger. I have ran in test tank for 15 min while setting timing and everything sounded and acted fine but have not open water tested. I hope to do that this in the next couple of weeks when I get more free time. I belive the bearings were the underlying issue to all of my problems
sutor623
Cool man! Im surprised CDI makes aftermarket parts for these old mercs. Id say you got lucky on that one. I had a '67 4 cylinder 650. That thing ran like a MONSTER. But if I had to replace just about anything on it, parts were nearly impossible to find, and I pretty much had to buy used. WWW.oldmercs.com had some stuff for it though. Good luck!
