75 mercury- oil pump?
razzor
This is my 1st ob and Iv bleed the oil pump but still not getting hardly any oil out of the other end of pump going into the fuel line, at the risk of sounding stupid, is it time to replace the oil pump and if so will that fix my other problem of acceleration, the motor sounds great and has a smooth idle, Just kinda feeling my way through this new toy before I spend alot of money throwing parts at it, Thanks bunches, Razzor
Chris1956
Re: 75 mercury- oil pump?
Razzor, You will need to post the year and serial number of the motor, so folks can assist with your issues. You may also want to describe your acceleration issues.
Most of all, do not run the motor if you suspect an oil injection problem.
razzor
Thanks Chris, Will do in the morning
