75hp 4 stroke blowing fuses
tygh
I have a 2005 Yamaha 75hp 4 stroke that keeps blowing fuses for the tilt control. I had it happen twice yesterday. Any suggestions on where to look for the problem??
Silvertip
Re: 75hp 4 stroke blowing fuses
Ahhh -- tilt system!! Are you using the correct size fuses? Even the factory can screw this up. Otherwise check motor current draw in both up and down directions. Up should draw considerably more than down. If its very near the fuse rating, the motor or pump may be dragging.
