Re: 75hp chry. runs and cuts off???
There might be a problem in the fuel delivery. Fuel tank vent, fuel hose leaks, primer bulb, fuel filter screen, fuel pump, and lastly the carburator. <br />If all is fine there could be a problem with ignition, electronic ignition cuts out when warm...I've never had this happen, but it's possible. If it were mine I would most suspect the vent or filter...loosen the cap on the tank to check vent. Remove the black plastic cover that is hooked to the fuel line...behind it would be a fine screen and sometimes it can get plugged and not allow enough fuel to carbs...just a Thought
