lyncraft_mechanic
- Joined
- Jun 22, 2007
- 233
I have a late model 75hp mercury 3 cylinder outboard probably from the early 80's, it has been stalling at high speed so i cleaned all the carbs and blew them out with compressed air, did a compression test and spark test all were up to specs. after the carb cleaning I saw an improvement but the motor still wants to die at anything above 3/4 throttle(like it's running out of gas) and has been idleing rough. does any one know what the correct air adjustment on the carbs are? is it 1 turn or 1 1/2 turns? does anyone have any suggestions on what could cause this problem?
