sharnholmes
- Joined
- Oct 3, 2008
- 5
My 1976 25HP Evinrude has a strong spark (1/2" blue spark) on #1 cyl & a weak spark (1/16" orange spark) on #2 cyl. The strong and weak spark swap cylinders if the ignition wire connectors are swapped just before the ignition coils, so I've seen both ignition coils produce a strong spark. I have replaced the points and condensers and have exactly the same symptom. Is it possible for the driver coil to be defective producing a strong spark on #1 cyl, but not #2? I also thought one magnet might be getting weak on the flywheel, but both are about the same strength when a screwdriver is brought near. I have inspected the wiring between the driver coil/points and the ignition coils and all appears good. There are no visible cracks or deterioration that might create a short to ground. I even disconnected the connectors leading to the kill/off position of the ignition switch to rule out a bad ignition switch.
Any help would be greatly appreciated.
