'76 40HP Evinrude Compression
Sunken Ship
I have exactly 90psi on each cylinder. Is this the correct amount for this motor? Both plugs were removed during testing. Thanks.
Sunken Ship
Been digging around...it appears that 90 is OK-not great. 90 was cold and without putting anything in the cylinders before testing.
nwcove
be happy that it both cyls have the same #. it should run ok at 90 psi
gm280
I have the '76 40HP Johnson version of your engine and my compression numbers were 115psi. But that really isn't as important as them being within 10% to 15% of each other. So 90psi can work without issue. You really have no idea if your compression tester is read properly or not. JMHO!
Sunken Ship
Thanks for the comments guys. I remember testing it back in '99 and it seems that it was closer to GM280's numbers. When I initially saw 90 I was sure worried! GM- I certainly do not have much faith in the compressor tester from Harbor Freight, but as you both said the two are perfectly even.
I really like this old engine. I have had it for so long I would hate to see it go down permanently over something major. I would probably re-ring it though.
GM- I just took a look at your motor. The only difference I see in the our motors is the color. Good to see another one still on the water!
