I'm new to outboards and I'm stumped.
This motor is hard to start as if it were not getting enough fuel. Sometimes, after it starts I can shut it off and it starts right back up, sometimes it doesn't. I changed the fuel tank, lines, pump and rebuilt the carbs. Once it is running it has trouble idling and dies when you put it in gear unless you give it enough gas right away. When idling it seems to backfire a little through only one carb throat every few seconds. Runs fine when wide open, seems to have plenty of power. I've been running it out of the water if that makes a difference. What am I missing here. Where should I look next.<br /><br />Thanks,<br />BR
