76' Bertram 28' restore Merc raw water pumps
captainmas
Another question regarding our engines 351 Ford Mercruiser. Can the raw water pumps be rebuild? The are salt water.:confused:
Thanks
Mike Mas
Bt Doctur
Re: 76' Bertram 28' restore Merc raw water pumps
If you mean the circ pump on the engine , no
If you mean the raw water pump that supplies the heat exchanger or directly to the engine , yes.
captainmas
Yes, The raw water pump is what needs to be rebuild, they were run in salt water and have sat for 3 years or so. New ones are 300.00 plus and used fresh water ones are about half, $150.00.
I've delivered some commericial vessels and know the raw water pumps are rebuild all of the time with new impellers and races. I was hoping these could be rebuild in the same way instead of replacing them.
Do you know were to buy the kits?
Thanks
Mike Mas
Ayuh,... Try the Mercruiser Parts links at the top of This page...
captainmas
I pulled them apart in between posts, they need end covers, o ring, impellars, cams and wear plates the #'s on the end cover is 59155, on the one pump is 46-63450 and the other is 46-73823. They may be Jabsco.
I did look here first put I cannot find the parts, any Idea's?
Mike
jtybt
I'd love to have a 28' Bert.
Straight inboards?
Jabsco's are all bronze. That's what I have on my boat. They're pretty much completely rebuildable.
I get parts from another source that I won't mention.
There have been raw water pump 'conversions' to the crank mounted styles if you have the room, which are easier to service compared to the merc version.
