'76 Johnson 115 - Shift rod set height?
brent.meeker
I have replaced my lower unit on 1976 Johnson 115. I couldn't find the shif rod set height in the service manual...so I called the local shop and he said he would show me in the book if I bought the book from him.
My actual problem...I can set the shifter dead center and I am just missing forward and reverse. I can adjust either way and hit forward or reverse, I just can't get them both at the same time.
Any help would be much appreciated.
Thanks,
Brent
MAW31
Re: '76 Johnson 115 - Shift rod set height?
brent,
I had recently installed mine, an '86 110 Johnson (same)
the shift-rod height from base to top of the shift rod in neutral was 20 1/8"
Once the foot is installed however, you cannot further adjust the shift-rod height.
your only recourse, is to drop the foot, adjust the shift height, reinstall.
except this time, only tighten 1 or 2 footer bolts while you confirm the shifter functionality to the controls.
put the shifter in neutral, and loosen or tighten the control connector to match where the motor mounted shift-lever is positioned in neutral.
emdsapmgr
Not sure just what it is for a 76, but the service manual shift rod height on a 77 85/115/140 is 21.411" plus or minus .036". In the factory manual, it is toward the back of section 6, where there is a diagram of the shift rod setup.
