Re: 76 johnson 200 cuts out when throttle up
That engine will seem to run fine when only running on 3 or 4 cyls. Check each plugwire to make sure you have fire on all 6. A simple cyl drop test will tell you a lot about the spark. You can pull each plug wire off a spark plug when it is running. Normally when you pull a wire of a plug, the engine rpm's will go down somewhat. Reconnect the plug and go on to the next. etc. If you pull one plug off and the rpm's don't change, that plug may not be firing. You can get the same results with an inductive timing light. If your spark check out, then start looking at the fuel system.
