'76 Johnson 25 hp water intake. Where?
barrynfla
Sorry for the kinda dumb question.......but where exactly is the water intake on my '76 Johnson 25 hp?
I'm putting a hydrofoil on the motor and want to be sure that I'm not covering up the intake.
Thanks!
Chinewalker
Re: '76 Johnson 25 hp water intake. Where?
The main intake is on the leading edge of the exhaust outlet, under the AV plate. You'll see a screen there...
barrynfla
Thanks, Chinewalker! That's what I suspected. It's right behind the prop if that's the screen I'm thinking of. I sure wish there was a way to put muffs on there but it looks kinda impossible.
kfa4303
Banned
yeah, no muffs on the older motors, just make sure you run it in a test tank with water filled 2-3" above the anti-vent plate and you should be fine. Don't be alarmed if the water gets yucky either. That's normal. If you do a bit of searching here in the forums, you'll find that hydrofoils are kind of a gimmick and usually don't do much, but mask/create other problems. You may want to try adjusting the trim/tilt and height of your motor first. The anti-vent plate found just above the prop, you should be level, or slightly higher than the keel of the boat and most folks find that trimming their motor out rot around the 2-3 pin hole from the transom is about right. I have a '66 20hp myself and I was able to improve its performance greatly simply by building a small transom riser raising the motor about 1.5".
barrynfla
Thanks, kfa. I can only get the cav plate even with the bottom of the center of the keel (tri-hull boat). I'm limited by the mounting screws on the motor bracket. They could only be moved up about 1/2" so I put a piece of solid aluminum on top of the transom to raise it 1/2". I trimmed out the motor to the 3rd hole and it looks parallel with the keel now. Haven't tried it out yet but I'll see if it's still level while on plane.
