76 johnson 25, smoke needle
trx88
alrighty, this motors come along nicely
after new points and condensers it runs on both cylinders
it idles nicely and seems alright except for two things
1) How do I know where the long rich/lean idle screw at the top of the carb should be at? I know you only go a quarter turn or so with them but since the carb kit its been off..
Ideas welcome
2) I am under the assumption that ive got this motor in good timing. I gapped the points to .020 like the flywheel says. However it still smokes more than i would think it should. Is it the cold outside?
Ideas welcome
1946Zephyr
Re: 76 johnson 25, smoke needle
Your motor should have the low speed needle set at about 1 1/2 turns out from bottom and the knob put back on right at the half way point, so you can have room to turn either direction 1/2 turn.
trx88
i bought it with the linkage wire, and the knob missing
i have tried making one out of a wire hangar, but it vibrates out at either end, and copper wire so i could solder a knot on the end and it wouldnt raddle out, but all copper i have tried so far is too soft..
trx88
yeah mine might smoke a bit more but i may just be seeing steam and the smoke because its cold outside
from the low idle needle
by the way that is a beautiful motor, mine is like that but its got a bad cowl and needs torso and pan painted and has an evinrude transom mount?
many many many thanks for the links and the needle help!
