This is a follow on to original post.
Motor ran great 3 times out. Then lost of power to 1/5 speed at WOT.
Cleaned/Rebuilt carb, replaced all fuel lines and bulb. cleaned tank etc. As suggested.
No improvement at all. Finally did compression test. Electric start
wot,nuetral,both plugs removed, 4 cranks 2 to 3 seconds each
Results: 80PSI cycl1 80psi cyl2.
After warm up same as above: 85psi cyl1 82 psi cyl2.
I noticed yesterday that on the upper portion on starter side of motor
that I saw bubbles of gas where the rear of the manifold meets the crank case, when running. Gasket plate to crankcase.
Is this the source of my loss of power and low compression. Shouldn't I be around 100 on each with 10/15%.
Let me know as this has gone on 3 weeks and haven't fished yet.
