76 johnson 35
karl1946_au
hi ther could you help me with my idl prob is ther a screw to do this as my shifter has not stop if i go to far off throttl it cuts out
OBJ
Re: 76 johnson 35
If the carb and linkage is set up right, look on the starboard side of the engine just below the pan. You will see a spring loaded screw. Run it in a bit till you get the idle where you want it. Keep in mind that you don't want the idle set to high...rough on the gears when you shift.
karl1946_au
Re: 76 johnson 35
ok yes i did see that thanx il have a look and il get back to you regards karl
G DANE
Re: 76 johnson 35
The 1976 35 HP has Point/condenser ignition. If the iddle mixture screw is set right ( do a search on iddle mixture ) a little weaker ignition on the one cylinder will cause it to stall at iddle. Has the ignition been serviced recently. You can check by pulling plugwires one at a time, put a screw or nail in the spark plug boot and hold it 5/16" from ground while a helper pulls starter rope. Both spark should jump to ground with bright blue spark.
karl1946_au
Re: 76 johnson 35
howdy i had a look at the iddle screw it is turnd out about a 1/4 of a inch but cant move it might have to get a new one also i found as i pull the lever all the way back it hits the iddle screw but the motor wont start at that pos it just misfires and now i have no spark on the top plug looks like the coil packed it in it lost all power yesterday when we took it out for a run was not a good day i was in the wooden boat festival so il get the coil looked at tomorrow regards karl
