Royce Brown
- Joined
- Jul 10, 2018
- 37
During the disassembly of the starter recoil (in order to replace a worn/chewed up pinion gear) I noticed that the Cam Follower is missing. I'm not sure exactly the purpose of the cam follower, as I've read it can cause issues and some mechanics will remove.
The motor started and ran prior to my pinion issue, but as I'm reassembling/installing the recoil starter is it worth the time/money/effort to add the proper cam follower mechanism? Does this help with alignment when placing throttle in start position?
I have had a difficult time getting the motor to start when I first purchased but seem to have sorted through that with new plugs and less priming before first pull start attempt along with the choke position. Basically I've had to "learn" my motor but I'm not sure of the cam follower function/purpose.
Any help/insight is greatly appreciated.
Cheers, Royce
Cheers, Royce
