76 Johnson 70hp Tach
knouse94
I have the sender to the tach hooked up to the grey wire in the harness. The tach zeros out when I put power to it and it is set on the 12 pole position. I am not getting the tach to pick up the motor. Am I doing something wrong? Thanks
eavega
Re: 76 Johnson 70hp Tach
Is your rectifier working? Check the top secret files for procedure. A faulty rectifier would cause tach not to work.
Rgds
knouse94
Where to I look in the top secret files I am not seeing it. Thanks
eavega
Actually, I didn't see this one under the Top Secret Files. Here is the tests that Joe Reeves sent out
Testing Tachometer With Water Cooled Regulator/Rectifier) (J. Reeves)
A quick check is to simply plug in a another new tachometer as a piece of test equipment. If the new tach works properly and the old tach didn't, obviously the old tach is faulty.... but usually boaters don't carry around a spare tach (see below).
A faulty rectifier wouldn't damage the tachometer, the tachometer simply wouldn't work. This is due to the fact that the tachometer operates off of the charging system and the rectifier converts AC voltage to DC voltage, enabling the charging system. A faulty rectifier disables the charging system, and the tachometer simply doesn't register.
However.... those water cooled regulator/rectifiers that are used on the 35 ampere charging systems (and some others) bring into play a different type problem, and as you've probably found out, they are really a pain to troubleshoot via the proper procedure. There's an easier way.
The tachometer sending/receiving setup operates off of the gray wire at the tachometer. That same gray wire exists at the engine wiring harness which is connected to the engine electrical terminal strip. You'll see that there is a gray wire leading from the regulator/rectifier to that terminal strip, and that there is another gray wire attached to it. That other gray wire is the wire leading to the tachometer which is the one you're looking for.
NOTE: For the later models that DO NOT incorporate a wiring terminal strip, splicing into the "Yellow Wire" mentioned will be necessary.
Remove that gray wire that leads to the tachometer. Now, find the two (2) yellow wires leading from the stator to that terminal strip. Hopefully one of them is either yellow/gray or is connected to a yellow/gray wire at the terminal strip. If so, connect the gray wire you removed previously to that yellow/gray terminal. Start the engine and check the tachometers operation, and if the tachometer operates as it should, then the regulator/rectifier is faulty and will require replacing. If the tachometer is still faulty, replace the tachometer.
If neither of the yellow wires from the stator is yellow/gray, and neither is attached to a yellow/gray wire, then attach that gray tachometer wire to either yellow stator wire, then the other yellow wire, checking the tachometer operation on both connections.
I've found this method to be a quick and efficient way of finding out which component is faulty.... the tachometer or the regulator/rectifier. It sounds drawn out but really only takes a very short time to run through. If the water cooled regulator/rectifier proves to be faulty, don't put off replacing it as they have been known to catch on fire with disastrous consequences
jtexas
ya, looks like the "simple rectifier test" is missing from the secret files, it's in the "Engine FAQ" section of iboats though:
http://forums.iboats.com/showthread.php?t=190638 That rectifier's not water-cooled.
A quick way to rule it out: measure the voltage across the battery terminals with engine off, then again with it running (all accessories off). If the voltage is higher when the engine's running, you know the rectifier is working.
If you can measure AC voltage on the gray wire with engine running, it means the tach is getting a signal. Some sources say at least 4 volts AC, others just say any AC voltage at all.
