Keyboardman
- Joined
- Sep 10, 2015
- 360
Hi all, The bottom carb isn't getting enough fuel to fill the float bowl. I've pulled the carb and checked that the needle valve isn't stuck or the inlet clogged. Fuel lines are all new and with no restrictions. A little fuel will drain out of the bowl after running, but not like the mid and top carbs. Possible weak fuel pump? The filter screen is clean. Thanks
