76 johnson 85hp lower unit help
river rat1
I got all the bolts off of the lower unit how do I get it off it stuck on there any help ty
emdsapmgr
There are four bolts that are visible on the sides of the lower unit. There is one under the end of the lower unit section over the prop. You will have to remove the trim tab to find the 6th bolt head. The lower unit will still not be free until you release the shift rod end at the bellcrank assy under the bottom carb.
