'76 Johnson stator going bad
timmyg
I replaced my stator on my '76 Johnson a few weeks ago (with a used one) the one that was on there melted down and quit working and now I'm worried that the new/used one is going bad. I see it is oozing. The local mechanic said it will do that because it gets soo hot under the flywheel. If this is true, can/should I try to vent the engine cover to help cool it or should I be looking for another problem?
Thanks, Timmy
JB
Re: '76 Johnson stator going bad
That engine is 32 years old. Don't you think if it gets too hot under the flywheel it would have died by now?
Please tell us what engine you have.
ezeke
Stators on the 1973 - 1977 series are not usually damaged by engine heat. In fact they run fairly cool because the thermostats are only 105 degrees.
What usually causes the stators to go is described in OMC Service Bulletin #1370.
Please click the thumbnail to enlarge.
timmyg
That's kind what I was thinking too.
Sorry it is a 1976 55 hp 2 cyl.
timmyg
Thanks for the SB,
That SB is talking about the charging side of the stator. Isn't the 8 small coils the charging side and the two larger coils the ignition side?
The 2 larger ones are the ones oozing...again
timmyg
This is some of the damage to the old one.:eek:
timmyg
Thanks for the SB,
Is my thinking on this correct?
timmyg
I know someone here has to have some info to help keep me from ruining another stator?!?!
jonesg
Did you check the service bulletin?
timmyg
Yes but it talks about the charging part of the stator and it is my understanding that the charging part is the small coils. The ones on mine thart are melting is the larger coils for the ignition part.
