I have a 76 Merc 7.5 HP.<br /><br />I have been having problems with it all year and have taken it to a dealer who basically told me it is not worth fixing.<br /><br />There is a little gadget that stops you from reving too high when in neutral. Well with the cowl off and in gear I can accelerate until just about where max throttle would be if it was in neutral. Anything past that and it starts acting weird.<br /><br />At WOT it speeds up and slows down and sounds like crap. Eventually it will stall but it is never predicable, sometimes it works like crap for 5-10 mins sometimes it stalls right away.<br /><br />To get it started I usuall have to thottle way up and put the choke on even when it is hot.<br /><br />I thought this might be a fuel / air issue so I tried setting the choke a bit (pulling out about 1/4 - 3/8) and when I did that I can go to WOT and it works great. smooth and steady etc. <br /><br />Do you think this is the fuel pump? That is is being starved for fuel when the choke is all the way in and the plate is perpendicular to the carb body?<br /><br />When it was at the dealer the guy told me that I have a bent drive shaft cause my prop was wobbling a bit when spun. and that there was water in my lower end.<br /><br />Could I just pull the prop off and run the engine to see if the shaft spins without wobble? cause it could just be a messed prop right?<br /><br />Any help / advice is apreciated.
