I just bought a boat with this motor. It ran fine with the flushing muffs hooked up, but not in the water. But for $900, I didn't expect much. I have a seloc manual in the mail and I can't get the links to the merc manuals to work. I was hoping for some pointers.
It stalled with throttle. When I squeezed, the primer bulb will keep pumping and not get firm. When primed, it keeps pumping the fuel out of the carb into the airbox.
I figured this could be a stuck float. So I got the parts to rebuild and pulled the carbs off one at a time. The lower carb was clean as a whistle. I cleaned and rebuilt anyway. The idle screw was out 2 1/2 turns.
The upper carb was also recently rebuilt and clean. The gasket was positioned incorrectly and preventing the float from moving. I put it back together, hopefully correctly. The idle screw was out 3 1/2 turns
After reinstalling, both carbs still squirt fuel out of the jet into the airbox. Idle screws are set to 2 1/4 turns from lightly seated. Yesterday afternoon it wouldn't fire at all. I may have just flooded it though. I don't think I messed up the wiring because I didn't disconnect anything.
Any insight would be much appreciated.
