This thing is giving me fits. I removed it to install a new water pump and as it turned out a lower exhaust seal. All that went without a hitch until it came time to put it back on the motor. I can get it on except that last 1/2 or 3/4 of an inch. I've read thru 80 pages of these forums and have had the lower unit on and off countless times. I guess I just can't seem to get the lower unit and the motor in the proper gears. I removed it with all in neutral. Since then I have tried forward and neutral or so I think. I've read that I should try it with reverse so hopefully that will work tomorrow.
This thing has whipped me ragged so far. Unless there are other suggestions please? Is there a sure fire way to tell what gear the motor and the lower unit is in. It seems no matter where I set the lower unit I am always in forward gear. Spins clockwise with the click. I have found neutral once, freewheels both ways. Anyone wanna lend me a hand in central missouri?
Thanks in advance much appreciated
