Motor Specs: I have a 1977 115 Johnson V-4.<br /><br />Symptoms: Starts and idles well but would begin to lose power after warm up (WOT = 5500 if I remember correctly, since its been awhile since I was able to get it on plane).<br /><br />Compression: Cold (warm) compression is 130 (125) in cylinders 2 & 4, on the port side, and 135 (135) in cylinder 1 with 115 (115) in cylinder 3, 1 & 3 are starboard side. Squirting oil in the cylinders causes more than a 20 pound jump in compression in each cylinder. <br /><br />Spark: When I pull the plug wires on 1, 2, or 4, there is a noticable miss, but pulling the wire on cylinder 3 has no effect. There is spark to cylinder 3 and switching the coil leads and plug wires with cylinder 1 makes no difference (i.e., either way, it still stumbles when the number 1 wire is pulled but no difference when the number 3 wire is pulled). <br /><br />Questions: Is there anything else that I can try to remedy the problem short of a new power head?
