manonfire296
- Joined
- Mar 23, 2009
- 12
just replaced lower starboard piston, have 80psi, wall was scored a bit, total rebuild will came later, need it running now. Have 100, 90 on port side. 120 and 80 on starboard. Was extremely careful not to disturb carb, and throttle linkage during tear down and rebuild. Also replaced fuel line hoses and put in an in line fuel filter. Plugs were replaced with CORRECT Champion plugs, previous owner used $1.50 Auto Zone crap. Also used carb cleaner to clean throttle and carb linkage. Motor ran well in tank after rebuild. Next day put in water and now I have trouble getting it to run. When it does run, it runs for only about 45 seconds, dies and backfires through the prop. I drained fuel, replaced with premium, and Mercury 2 stroke oil 50 to 1. bulb is hard, and fuel is entering the carbs, although it seems like it floods a bit. Compression in starboard side dropped to 30psi in both cyls. I think that might be the gasket. Any sugguestions?
