Re: 77 25 hp evinrude running hot
You can drop the lower unit again and try blowing air up the water tube(s).If it is definetly blocked,yes you have a blockage somewhere.Unfortunately if SOME air goes thru,it proves nothing because air will go past a partial blockage easier than water.<br /> We usually pull the powerhead and cylinder head as well as exhaust cover,follow water passages,and clean all.DHP
