Jggrmson
- Joined
- Oct 8, 2010
- 40
*Skip to more recent posts* full story below
Ok...here is the deal, received a 16' jon boat with a 35hp electric start outboard from my parents who...are getting to old to fish. they bought it 5 years before i got it and let it sit in the back yard for 4 of those years with gas in the tank, lines and carb.
here is what it is doing.
1st got it, wouldn't start at all. cleaned the carb, started ran rough, coughed and died. after running it on the lake 1/4 throttle for an hour or so it worked out the dust and ran "OK" except when i put the throttle past a quarter power. i later discovered that if...when i pushed the throttle past the 1/4th mark...just when it was about to die, i pulled the choke (close) it would recover and give me 1/2 power (throttle) unless i power down to 1/4 which it will die unless i open the choke again. whhheeewwww **panting**
here is what i have done since then.
Cleaned the carb again. it was still very clean from before. used 4 can of carb cleaner, pulled the bowl off, sprayed in the jets and came out clean. used compressor to blow the ^^^^ out of it. basically cleaned it for hours and feel confident about it.
replaced the gas tank fuel line from tank to motor, rebuilt fuel pump/filter. replaced all gaskets from block to air box. inspected all fuel lines within the motor. cleaned it a lot.
the motor starts and runs great in the yard with the 'ears' on it. runs good in the water at idle and slightly above idle speeds. as soon as you power up...cough, cough. same stuff.
my pride has been pricked and i really don't want to take it to the shop.
